drj434343
Newbie
Greetings all. I'm considering upgrading from airhead to oilhead, and I often come across oilheads with less than complete maintenance records. I've read about 40K spline lubes, transmission failures, and paralever bearing play.
In this particular instance. I've found a 1997 R1100RS with 59K on the odometer. It has had several owners. There is a Clymer manual included that has notes from previous owners about fluid changes, tire changes, and general maintenance. I do not believe there are any indicators of major service.
So the question is, what kind of risks are there when considering a bike that may have never had its splines lubed? Should assume an immediate lube job? Should I walk away because the splines may be toast? Are there things I can do to try and evaluate the condition of the splines/transmission/paralever system?
All things being equal, what kind of opinions on value do people have if a bike like this has decent indicators of regular maintenance, but no indicators of major service? I'm sure I can tackle a spline lube myself, but don't want to risk splines that are already toast.
Opinions?
Opinions?
