DrPaul
DrPaul
The bike:
2008 K1200GT, stock suspension and shocks.
30K miles (now).
Michelin PR3 tires with (now) 5K miles. Front = 38 psi, rear = 40 psi.
The situation:
Just returned from 11 day, 4.8K trip from Oklahoma to New England and Canada. Left with new (300 miles) Michelin PR3s front and rear. On the 9th day of the trip about an hour before laying up for the night, I noticed the bike start to wander a bit at highway (60-70 mph) speed. At slower speeds (20-40 mph) steering seemed very heavy, not wanting to fall easily into slow speed turns. Had this exact sensation several years ago when I lost air pressure in the front tire. Stopped and checked (tires hot) and pressure was OK. Examined both tires and could find no problems. No unusual wear, cupping, tire chatter in turns, etc. Next day, all was well until several hundred miles then same symptoms. Same problem on last day of trip, OK for first few hundred miles then symptoms recur. Again, careful tire inspection reveals no problems.
I feel that the front suspension is the problem since I can't find a tire issue. Any ideas on what may be the cause? Thanks.
30K miles (now).
The situation:
