Yes, it is the weep hole for the water pump and they have been known to leak. In 15K on my '13 GSW I've now found small indications of fluid loss twice; the last time was last week. I'll clean it off again. If more indications show up it will be off for repair. A mechanic at a local dealer says it is not common, but not unusual, either. He's changed 3 water pumps.
On my GS both times I found indications of leaking was after a trip that included high ambient temps and sections of slow speed dirt or other technical roads that had the cooling fan on often. Might be coincidence, might not. I have not lost enough coolant from the overflow reservoir to bring the level below the min mark.
I wonder if BMW knows how to make water pumps. The K1600 and now this.
Maybe they order them from the same folks who supplied Yamaha pumps for their FJR bikes.
I recall that my 85 K100RT had a water pump a "couple" of years earlier.
I saw a thread on another web site in which some posters have pointed out that some of these water pump seals leaked for a while, and then stopped. If this sounds hard to believe, I had a seal on a rebuilt transmission for my old '86 K75 leak for a week or so and then stop, and never leaked after that.
Thread here: http://www.ukgser.com/forums/showth...e-a-hole-in-their-2014-GS-Crankcase-like-this
Harry
