rogermansfield
beemerfield
It won't stay in the up position! The old spring seemed a little weak, so i got a new one. Didn't hold the centerstand in the up position. Tried "flipping" the hook over and that didn't do anything. I took the stand off and am looking at the spacer/bolts. A little worn, not too bad, but I would think that some wear would actually help. (but i've been horribly wrong before).
This is a standard/stock centerstand/spring on a '71 R75/5 SWB.
There is also a "pin" on the centerstand right side and a "hook" at the front engine mount. They are not being used. I can't recall them ever being used on any bike I have seen. Why are they there and is the remedy simply to instll another spring there?
