Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 61 to 75 of 85
Thread: Learn Garmin BaseCamp Tutorial Videos
  1. #61
    Canada and the Alps
    Quote Originally Posted by patm View Post
    It means pavement ends. Road is now a dirt road.
    Exactly the way I understood it, except the road is paved all the way through.
  2. #62
    Registered User mylanc's Avatar
    Aug 2013
    Cape Elizabeth, ME
    Thank you!
    I just completed a trip around Nova Scotia this past week using my new Zumo 595LM and BaseCamp. I just want to thank you, Don, for all the work you've done to educate people about BaseCamp and for keeping this thread going. Also, thank you to Ed Conde and Steve Bruning for their excellent written manual/tutorial referenced in the first post in this thread - invaluable! I couldn't find their email addresses so I hope they see this. They've created a very helpful resource. The info here and from them helped make our trip easier and even more enjoyable.
    Keep up the great work!
    2012 F650GS
  3. #63
    Canada and the Alps
    How do you send someone a "route" that is in your Basecamp list?
    Normally, I'd go to a Garmin folder and attach the route in an email.
    I've done it once before but can't remember how I did it.
    Got it.
    "File" then "Export".
  4. #64
    That road looks good! Norwood's Avatar
    Aug 2005
    From NW AL to WNC
    Quote Originally Posted by mylanc View Post
    Thank you for those comments.... Glad it was of some help.... Ride safe!
    MOA Ambassador, Member of AL, GA and Chattanooga Clubs, MTF Gold member and BOD.
    2011 R1200 GSA with DMC sidecar; G650GS.
    My annual charity event: http://www.echbenefit.com/
    " Oh Lord I pray, Let me live long enough to do everything they say I've done"
  5. #65
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    Basecamp, Google Earth Pro and Mac
    For those like myself who have a Mac and use Basecamp and Google Earth Pro, the issue is that Basecamp and GEP don't work together. The simple solution is to rename GEP just to Google Earth in the computer.
    1 Go to finder
    2 Go to Applications and find GEP and highlight
    3 Go to file and click rename
    4 Remove Pro from the name.
    5 Enter and done.
    Hope this helps.
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, 17 R1200RT
  6. #66
    Tourmeister gr8ridn2's Avatar
    Jun 2009
    Kern Valley CA
    Quote Originally Posted by RIDERR1150GSADV View Post
    1 Go to finder
    5 Enter and done.
    Hope this helps.
    Thanks for the very useful tip on Google Earth Pro. I tried your directions and the issue was resolved.
    2018 R1200RT W - Continent traveler
    2016 S1000XR - Smile Maker
    1976 R90/6 - Just Plain Fun
  7. #67
    Apr 2017
    S.Florida
    You're welcome!
    MOA # 108516
  8. #68
    1 Go to finder
    5 Enter and done.
    Hope this helps.
    I also have a Mac, Basecamp, etc... Probably a crazy question, when creating a custom route in Basecamp, what do you use Google Earth Pro for ??? I don't understand how you use the two programs together ??
  9. #69
    Central Ohio
    Google Earth provides a satellite view of your route, useful to determine road conditions, surroundings, scenery potential, zoom in and check out potholes, gravel, see road signs to check speed limits, preview your destinations, see what sort of neighborhood your motel is in, etc. At one time there was an option to "fly" over your route like an airplane at low altitude, but I'm not sure that is still possible, it was always a little finicky and I do not have the necessary patience to watch it anyway.
    In Windows, Earth is accessed via the View item on the menu bar with options to start centered on your route, on selected items, or simply on the current Basecamp display.
    I find it simpler to just use Furkot.com for most of my planning as it already uses Google Maps and I can switch between road, satellite, and terrain views with one button and change the route from the alternative views. My travel netbook has limited memory and storage, so I prefer not to install Earth on it.
    Larry
    2006 R1200RT
  10. #70
    Thanks for the info, I will give Furkot a look....have not tried it.....
  11. #71
    Apr 2017
    S.Florida
    Quote Originally Posted by dfisher1 View Post
    Down here we have many rural roads that are either gravel or paved. On the RT I prefer the paved version. I use google earth to check on that by zooming in as close as possible. You can open google earth in basecamp and see your routes projected in google earth.
    MOA # 108516
  12. #72
    I didn't realize you could access Google Earth from Basecamp !!!!! I will see if I can find the access and try using it as you suggested.... seems like a good tool !!!!!! Thanks for the info........
  13. #73
    Hey Chromehead ! bobs98's Avatar
    Nov 2005
    Marlton, South Jersey
    Me either. I'll have to try that. Thanks!
    Bob Smith
    1998 R1200C
    2005 Rocket III
  14. #74
    Apr 2017
    S.Florida
    You're welcome guys!
    MOA # 108516
  15. #75
    I guess I am a little dense this morning !!!!!!
    I have an iMac computer, in Basecamp, how do I access Google Earth ????
    Is that part of "Birdseye" that says it is a subscription service ????
    Thanks again.......
