Results 1 to 6 of 6
Thread: Starting Issue
    Starting Issue
    I was riding with a friend recently and we rode about 90 miles on a 75 degree day and stopped for lunch. After lunch (an hour or so), his bike (a 2004 R1150RT with about 21000 miles) would not start. It would not turn over at all although the headlight came on. The clock zeroed out. After letting it sit for a few minutes, it started. We reset the clock and it kept correct time all the way home. Anyone ever experience this? Any suggestions as to what might have happened?
    Thanks.
    Jim
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Check the battery connections first. A loose/corroded one will exhibit that fault.
    Ufda happens..........
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    That's a good place to start but don't stop there. Check your grounds, thoroughly and then pull all the fuses and relays and re-insert.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Oct 2011
    Florida & Massachusetts
    Quote Originally Posted by 217don View Post
    Thanks.
    Jim
    Your lights lit brightly, but the starter brought the battery to its knees. Then everything worked. It happened to me too.
    It seems most likely to me that he has a problem with the starter. There are a couple ways that Oilhead starters draw excessive currents: the planetary gear cover inside the starter drops onto the armature; or magnets break loose inside the starter and jam the armature. In both cases you get the symptoms you experienced.
    By all means follow the earlier good advice but also disassemble the starter and check it out.
    http://forums.bmwmoa.org/showthread....use-of-Failure
    Thanks for the advice; I'll pass it on.
    Jim
    Likes curves! Kyle L B's Avatar
    Jun 2010
    The SNAKE 421. Bristol, Southwest Virginia
    Seen that myself. I cleaned it all up, straightened the center plate, and epoxied it in place before assembly.
    Sent from my GT-P5210 using Tapatalk
    04 R1150RT
    09 R1200GS
    Homemade trailer for behind Both.
