Results 1 to 13 of 13
Thread: 2012 R1200RT Final Drive oil volume
    Estesdon selledr's Avatar
    Nov 2011
    Estes Park, CO
    I am doing the 12,000 mile maintenance on my 2012 R1200RT and I cannot find a reliable reference for the volume of oil to add to the final drive. I don't have the maintenance DVD because I use Apple computers. One post on this forum (in the Tech Library) called for 180 ml while another said 220 ml.
    Some references elsewhere on the internet say that BMW issued a bulletin changing the volume to 180 ml because the earlier required volume of 220 ml created too much pressure and can damage the rear oil seal.
    Can anyone answer this definitively?
    Also, I purchased Mobil 1 Synthetic Gear Lubricant LS 75W-90 Synthetic Gear Lube for this purpose while the Tech Library shows Castrol SAF-XO or BMW Gear Oil SAE 75W90 Super Synthetic. The Mobil 1 is not dyed red as the Castrol and BMW products apparently are. Comments?
    2012 R1200RT
    2005 F650GS
    Sep 2006
    CENTEX USA
    180ml is the standard since the reduction from the original build spec of 220ml
    saf-xo is the original spec, now available at dealers . I and others have used the Mobil 1 for years before the xo was available. Spectro, now Castrol bottle for BMWNA.
    The spec is recommended...not required...a big difference to most of us
    If the xo was the only option, dealers would not sell/install the BMW labeled juice...which they do.
    Nov 2011
    Estes Park, CO
    Thank you!
    Wow, Thank you Steve for the good info and thank you so much for your quick response!! My RT was sitting in the garage with the oil drained from the final drive when I made my post. Now I can proceed with the oil change with only a 30 min delay (which I spent having lunch).
    Isn't this forum great!
    Thanks again!
    2012 R1200RT
    2005 F650GS
    Registered User hdehaan's Avatar
    Jun 2014
    Portland, Oregon
    Quote Originally Posted by selledr View Post
    My 2011 R1200RT has a vent so overfilling is not that big a deal. I assume your 2012 R1200RT has this vent as well so you shouldn't have any problems either.
    _________________________________________
    HDH
    2011 R1200RT
    Nov 2011
    Estes Park, CO
    Quote Originally Posted by hdehaan View Post
    That's good to know, hdehaan! Thank you.
    Can you describe the vent or show a photo so I can verify that my RT also has the vent?
    2012 R1200RT
    2005 F650GS
    180 ml is the amount currently called for by BMW. It used to be higher, but they reduced it (due to rear drive pressure issues is my understanding).
    Castrol SAF-XO is golden coloured. It's about $22 per liter in the US. But, on my 2011 R1200GS, the rear drive only requires changing every 20,000 km, and the gear case only requires changing every 40,000 km, so the cost per km is very low. So I stick with the Castrol SAF-XO.
    see realoem.
    Part 8 is the breather
    Dec 2010
    Boston
    I refill rear end via the vent cap hole
    Registered User natrab's Avatar
    Sep 2012
    Antioch, CA
    Quote Originally Posted by T-foiler View Post
    I was curious about this as I didn't know what that cap was until now. If you can fill it through the vent hole, that would negate the need to remove the rear wheel to get to the filler plug.
    Anyone else do this?
    Current rides:
    2016 R1200RT Ebony Metallic - 12k miles
    2012 R1200GS Rallye - 18k miles
    Previous BMWs: 2013 R1200RT 90th, 2011 R1200RT-P, 2007 R1200S, 2006 R1200RT
    Jun 2014
    Portland, Oregon
    Marchyman already posted a link to the exploded view drawing but below you'll find a picture as well.
    HDH
    2011 R1200RT
    Jun 2014
    Portland, Oregon
    Quote Originally Posted by natrab View Post
    Yes, I have done that. Be careful to pour slow otherwise you'll spill oil and you'll lose track of how much is actually going in the final drive housing.
    HDH
    2011 R1200RT
    Does the breather simply pull out (as opposed to being screwed in)?
    Thanks,
    Dec 2010
    Boston
    Just give a pull at angle. I put a rag around the hole and fill it. It's so easy and the drive has no sight glass I change the oil twice a season, not because of wear and tear of the oil but because I want to know there is enough oil in the drive
