Results 1 to 3 of 3
Thread: Cross Reference
    Cross Reference
    Due to an accident with an uninsured truck I am trying to rebuild my 1993 r100r. I need several fork parts. I understand several parts are common with k75 & k100's of the same period. How can I find out what bikes uses the same fork, headlight, windshield....
    Hank
    Liaison 20774's Avatar
    Welcome to the forum! See if this helps...go to RealOEM online and type in the R100R part number...then search on that. It give you a listing of other models it was used on.
    Quote Originally Posted by Hank Widdop View Post
    Hank
    Use the search feature at Max's BMW website. If you find out the proper part number, then search for it and the site will tell you every bike that uses that same part!
    "The difference between death and taxes is that death doesn't change every time congress meets." - Will Rogers
