Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 46 to 60 of 78
Thread: Fuel Sensor Strip Warranty
  1. #46
    Urbana, IL
    Quote Originally Posted by 20715 View Post
    Well, I can tell you I'm calling Gateway in the morning to make sure they're not using year old stock. Just in case.
    I like the guys at Gateway. Shannon and Ryan have always treated me well. But I would have got this next one at Sportland if they'd work on Saturdays. That's the first dealer I've ever seen that didn't work on bikes on Saturday.
    I think it varies. They are closed on Mondays except during the summer months. So I think they do service on Saturday in the winter. In the summer the mechanic puts in 5 days and Saturday would be all overtime.
    No dog in the hunt, just saying.
    I like the Gateway guys too and have known Ryan since he was a baby Dink. But I like Sportland too and it's a mile away.
    R1200GS LC Rallye
  2. #47
    Still plays with trains. tinytrains's Avatar
    Oct 2009
    Torrance CA
    My dealer just confirmed the 12 year warranty.
    2009 R1200R Roadster
  3. #48
    Clovis, NM
    As far as your third strip - sounds like it was replaced after BMW pulled all the in-stock strips from dealers and replaced them (around April of 2013 I believe.) My friendly local shop service manager when last I checked still hadn't had to do any "redo's" on strips replaced since then. He thinks the vendor (who likely also made the fuel pump) might have found a fix.
    I had my 07 RT at Sandia BMW in Alb for some other work and the service manager and I discussed my fuel film strip - this one was number six I believe. Mine "worked" but was generally inaccurate and unreliable. It wasn't unusual for me to fill the tank and the display never reach much more than between half and three quarters of a tank. Topping up from my fuel cell while under way with this fuel film strip never showed more than a quarter of a tank of fuel. It should have shown at least a half a tank once the fuel was transferred to the main tank.
    While the bike was there, the shop did the recall replacement of the fuel pump, a warranty replacement of the fuel film strip and calibrated the fuel film strip. Testing the fuel film strip, the shop comments were "Found Fuel Gauge Implausible. Tested Fuel Film Strip - Pins 1and4 "OL". Faulty Fuel Film Strip."
    I fueled in Alb and immediately noticed that no sooner did I have the key on and the fuel display was at full within abut 10 seconds - if that. Riding home [240 miles] I paid attention to the behavior of the fuel display. Unlike any previous fuel film strip, this one actually shows a gradual display of fuel used that appears to actually track what I would expect a fuel gauge to as fuel was consumed. When it showed just over a quarter of a tank, I opened the valve to start the transfer of fuel from the fuel cell [it's a gravity feed system]. Very slowly, roughly at a reasonable rate I would expect based on experience using the fuel cell - the display gradually increased to slightly more than half a tank before I decided to shut the transfer valve off.
    I would agree that it is possible based on that experience yesterday, the vender may indeed have actually gotten this nuisance issue finally resolved. Only time will tell.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
  4. #49
    I read in another forum that BMW may reimburse owners of failed fuel strip if they paid out of pocket for the replacement. Have any of you had any experience getting a refund?
  5. #50
    Boxers uber alles sagerat's Avatar
    Jul 2006
    Central Oregon
    Gads, a fuel gauge that actually works; I'd be thrilled. I'm on my third one on my '09 GSA and it's about as accurate as a $2 watch. I'll contact my BMW dealer in Eugene and see if I'm eligible for a replacement. My work around, is just to start looking for fuel at 275 miles, look harder at 300 miles, and become desperate at 320 miles.
  6. #51
    Quote Originally Posted by tinytrains View Post
    My R1200R runs almost exclusively on Chevron with Techron, and the fuel strip still failed. So I don't that helps the fuel strip.
    The plus side, it Chevron has excellent stability. It takes me a 2 months to use a tank of fuel in my K75 and pick-up truck, but I never have "bad gas" problems or fuel system clogging in either.
    +1 on my '09 2 strips replaced now, almost exclusively run Chevron w/Techron
    "The Older I Get, the Faster I Was"
    '09 Black Metallic Sapphire "Fully Farkled" RT
  7. #52
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    Got my new 12 year version of the fuel strip today. Old one mostly worked, but I was getting the fuel pump replacement recall done so I had the fuel strip done also. Hopefully it works as well as the old one. Old one got inconsistent from half tank down (sometimes would show 2 bars, sometimes 4) but as I got to were it should be showing 2 bars (300 miles on my GSA) it would settle down and was fine for the rest of the tank. Since this is my first bike with a guage, I just rely on the odometer anyway.
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA 2013 K1600GT
  8. #53
    May 2010
    Austin, TX
    Actually, just checked my reciept and it looks like they only did the fuel pump warranty and mounted tires. Guess I'm headed back for a fuel strip.
    Rusty
    Austin, TX
    Two Wheeled Texans
  9. #54
    Clovis, NM
    Quote Originally Posted by siman00 View Post
    Not on the fuel strip - however, I just received reimbursement for the replacement fuel pump I paid for in 2012 on the way to the rally.
    Nom de Plume:
    BMW MOA #6218
    IBA# 442
  10. #55
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    Is this warranty extension for US bikes only?
    I spoke to a dealer in Montreal today because mine failed and he wasn't aware of any warranty extensions on fuel strips.
    Has anyone in Canada had their fuel strip replaced under this extended warranty?
    Can I bring my Bike to a US dealer and have them replace it?
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
  11. #56
    Registered User Paladinwest's Avatar
    Jun 2010
    BC South Central Interior
    Canadian Fuel Strip Replacement Policy
    A friend of mine had his replaced (2008 GSA - long after warranty) but it was done ex gratia after he wrote a nice letter to BMW Canada asking why it was covered in the US and not in Canada. In trying to get it fixed he also found out that the US extended warranty only applies to bikes with US VIN's. (A US dealer that we both use thought that it would be no problem to do the work and found out differently). There is no official recall/warranty extension in Canada. I had one fuel strip replaced after the first year on my 2008 GSA (warranty). In that case the gauge might not read full after filling up (it took a long time, if ever, to light up the last segment of the display, but worked fine otherwise). I did notice in the seven years that I had the bike that after extended trips into the US the new strip would be slow to register full but after a week or so of sitting with a full tank of 94 Octane no ethanol Chevron gas it would go back to working normally. Not sure why but that always seemed to be the case. When I had the original one replaced I had just been to the rally in Gillette.
    2014 R1200GSA 38,000, 2008 HP2 Sport 11,000, 2008 R1200GSA 100,000 (Sold), 1990 R100GSPD 102,000, 1986 K100RS 154,000
  12. #57
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by Paladinwest View Post
    I sent an email to BMW Canada about it.
    I'm waiting for their response...
    Daniel
  13. #58
    Registered User alegerlotz's Avatar
    Mar 2015
    Greater Los Angeles
    ...I did notice in the seven years that I had the bike that after extended trips into the US the new strip would be slow to register full but after a week or so of sitting with a full tank of 94 Octane no ethanol Chevron gas it would go back to working normally. Not sure why but that always seemed to be the case. When I had the original one replaced I had just been to the rally in Gillette.
    My 2005 RT is new to me and until recently my fuel level would take a while to come up and my "miles remaining" would take forever to reset.
    I ran 2 tank fulls of fuel with some Techron through the bike because it was buzzy when riding on the highway (my first BMW R bike, so I didn't know if this was normal) and not only does it run a little smoother, but the fuel gauge resets fast now.
    2016 R1200RT
    2007 KTM 450 XC-W (10/17 - 5/18)
    2005 R1200RT (2/2015 - 12/2016)
    1985 Yamaha XJ 700 Maxim (7/1989 - 9/1991)
  14. #59
    Sep 2010
    Hiawassee, GA
    Fuel Strip Warranty
    I got the notice in August 2014 that there was a warranty on my 2007 RT. I put in a claim for reimbursement and was told today that BMW wouldn't pay anything because I did not have an authorized dealer do the replacement. I was only seeking reimbursement for the part. After I got off the phone I re-read the warranty letter. It says that BMW will reimburse the out of pocket expense for the fuel strip if the work was not done at an authorized dealer. I've send another email to the customer service department telling them that I thought they were wrong in denying my claim and I quoted the language from the August letter. I haven't heard back yet.
    Has anyone else been denied their claim? What were the reasons given?
    I personally think that the labor should be reimbursed in my case because I did use an authorized service shop, just not a dealer.
    Mary
    2007 R1200RT, gone
    2009 R1200RT, gone
    2014 R1200RTW, GREAT
  15. #60
    Dec 2013
    Laval, QC, Canada
    This is the answer from BMW Canada:
    While there is not an extended warranty released by BMW Motorrad Canada for the fuel strip, we are reviewing assistance requests on a case-by-case basis. To determine if assistance is available for your motorcycle, please consult your Service Manager when you have your appointment with your local BMW Motorrad retailer. During your appointment, please speak with the Service Manager, who will then submit your request for assistance.
    I went to the dealer and BMW will replace it as a goodwill gesture.
    I have an appointment next week.
    Daniel
