R12R Left Side:
The clutch lever (including the master cylinder and reservoir) has its own clamp, and can be rotated around the bar. The mirror stalk screws into the clamp; if the clutch lever is rotated around the bar, the mirror stalk moves with it.
The left handgrip is mounted on a plastic tube; the tube slips over the end of the handlebar, and is held in place by two self-tapping screws through the end of the tube into the handlebar. The tube also has a tab on the inside end. The switch module is screwed to the tab. At least on the R12R, the switch module's position is fixed by its connection to the tab; it can't be rotated on the bar unless the grip's plastic tube is also moved, which would require new tapped holes for the two self-tapping screws.
