Results 1 to 7 of 7
Thread: F650GS volt meter
    F650GS volt meter
    Has anyone installed a volt meter on the F800/650GS yet? I was thinking of installing one to keep an eye on my stator and don't want to fry my electrical system.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Argus Battery Bug. Not a true volt meter, but it will meet your needs I believe.
    Kevin Huddy
    Silver City, Montana
    MOA# 24,790 Ambassador
    Aug 2008
    North Carolina
    Registered User Antman's Avatar
    Nov 2003
    Florida
    wanderer
    Jun 2009
    Bridport Vermont
    If you don't want a large meter, there are a couple of companies that offer small LED indicators. about 1/4 inch diameter.
    These go from red (discharge) to yellow (on the margin) to Green (charging...normal while running the engine). I have one of these,and like the small size ..and the important info.
    Sorry I've forgotten the source and the exact voltage ranges. Maybe Aerostitch??
    Aug 2008
    North Carolina
    I have this one:
    http://f800riders.org/forum/showthre...mp-GPS-adapter
    Tells me what I want to know in one small LED:
    The LED shows system voltage level in 5 steps:
    Flashing Green - Voltage Above 15.25 VDC - This prolonged over-voltage condition can destroy batteries, especially gel-cells.
    Steady Green - Above 12.9
    Steady Amber - Above 12.6
    Steady Red - Above 12.1
    Flashing Red - Below 12 VDC - During this condition, if the engine is running, do not shut down until service can be provided. Restart of engine is unlikely. Reduce electrical load.
    Cum opus clava fecit nihi
    Okanagan Valley, BC
    As the pre-2013 F800s are prone to stator burnout I installed voltage monitors on our two bikes some years back. I installed this one:
    http://www.sparkbright.co.uk/sparkri...ge-monitor.php
    The other day it did its job alerting me to an intermittent low voltage condition. I had a stator and cover gasket on hand so it was only a day to repair myself.
    BMW never did admit to this design fault, it just quietly changed the flywheel to provide better cooling in 2013.
    I plan to convert to series type regulators this coming winter as they contribute less to stator heating.
    I have read that the water-cooled 1200s and 1250s are having stator problems as well. This really should not have happened given the history of stator issues. On those bikes the entire engine must be removed to get to the stator. Huge cost if you can't do it yourself.
    Here we see my apprentice "Thing" demonstrating that a winding has shorted to ground.
