As a frequent Canadian traveler to US, I always found myself frustrated when I couldn't "Pay-at-the-Pump" (PATP) with my credit card because the fuel station security program asked for a ZIP code. I'm partially disabled, so I often find even one trip into the kiosk to pay (never mind two) more than I'm comfortable with.
Additionally, most such stations mandate pre-payment in the absence of a valid credit card, so a fuel stop can often wind up like this:
-Pull up to the pump, insert my card and answer the tiresome questions (no, I don't have a rewards card; no, I don't want a car wash; etc.), only to ultimately be asked to enter a valid ZIP code. PATP failed, must pay inside first.
- Walk to the kiosk, wait in line. I am given the choice of leaving my credit card with the attendant, or pre-authorizing a set amount. Not wanting to let my credit card out of my sight, I pre-authorize more than what is required to fill my tank, say $30 US.
- Walk back to my vehicle and fill my tank. It takes, say $20 US.
- Walk back to the kiosk, wait in line again. Finally ask for the refund to be credited back on my card. The $10 US comes back to my account at a less-favorable rate of exchange than it came out for, meaning it winds up costing me more money than the straight transaction, for less convenience. Another wrinkle is that refunds or "credits" can take up to 2 weeks to appear on your card account.
Sure, I could use cash (still requires 4 trips back-and-forth though), or not top up my tank, but still, the convenience and simplicity of PATP is essentially denied for Canadians touring the US. I have fought and railed at the credit card companies for years, to no remedy or effect.
Until now.
I became 'aware' of a method for Canadians to respond with a "valid" ZIP code when prompted by the pump security programs. The credit card companies and the fuel companies apparently do not know about it (they certainly don't share or publicize the info), but I've just returned from a many thousand mile driving trip through the US, and it worked at every pump I used.
Canadian postal codes are alpha-numeric, consisting of 3 letters and 3 numbers. US ZIP codes are 5 numbers, so the pumps use numeric keypads only. To obtain a "valid" ZIP code that will match your card data, enter two zeroes followed by the 3 numbers in your postal code (in order).
For my postal code of S6H 0N8, my pump ZIP code becomes 00608. Problem solved.
Note that this is not illegal or fraudulent, and still technically satisfies the security requirements of the fuel and credit card companies. I don't know why this information is so "secret" or poorly known, but regardless, it works.
To all you similarly frustrated Canadians touring the US, give it a try. And when it works, spread the word to more of your countrymen.
Cheers
JP
Until now.
Cheers
JP
