What is the normal operation of a gray BMW battery charger for a 2006 R1200RT? I?ve done the prescribe turn on procedure to connect it with the bike. The power light is green and error light is not lighted. All upper LEDs light up briefly and then the upper left LED is red. After some time the upper left LED starts flashing. Following this the 2nd LED will be on for awhile followed by the third LED. The 4th LED (upper right) may come on, but I?ve never seen it. After going through this sequence it reverts to the first LED which will flash red. Then it will stay on the flashing red LED. A check of the battery voltage indicates 12.7. Should the battery charger stay on the blinking red, or stay green on the right LED? The charger model number is 71 60 7 688 865. Thanks for any insights you may have.
