Does anyone know if anybody sells the white instrument ( here speedometer) needle as a part? I hate to send a speedo to Palo Alto and have them charge me $200.- to replace a broken needle.
I was amazed how light that needle is. A toothpick probably weighs 10x as much.I'm thinking that you could just glue on a toothpick! Wouldn't that work?
I will contact Terry, thanks all. No, Jim, i did not know you were kidding....
The needle is a thin metal part that is clamped on the hub with four small bending tabs. It looks like it would be available as a spare part.
If you get the needle it should come with the small brass hub too. The old one can easily be removed by grabbing it (needle and hub) with a pair of needle noise pliers and pulling straight out. It pops off the shaft easily. Replace it the same way. I removed mine to recalibrate the speedometer.
Wayne
What Dennis said, and this is a good time to correct any speedo error too.
Wayne
I think I will forego any calibration attempts. I am not concerned at all about having an exact indication of speed on a vintage bike and I rather have the safety net of seeing a few mph more than I am actually going. Saving me the discussion with the cop that I went too fast in 55 mph zone.
It seems the hub is set on the shaft such that the needle, if mounted, points right at 0 and touches the pin. I will leave it at that.
That is not the way I removed my needle. Wayne
