twins4life
I can no longer order Staintune, my bike is a discontinued model so I decided to see if I could remove the CAT element from the stock muffler.
Several cuts in the wrong places and I finally found where to remove the sheet metal to get at the CAT element. The steel is VERY thick, I used a 1/16" grinding disk. My welder is very good and he assures me he can weld it back. If I had known where to cut I would have only needed one cut. Oh well.
Hopefully someone else can benefit from my experiment.
