Results 1 to 8 of 8
Thread: Torx Driver Oil Drain Plug GT
    Jun 2012
    Paramus, NJ
    Anyone know where I can buy the M24 Torx bit for the oil drain plug?
    I've searched all over with no success.
    Thanks,
    Peter
    No longer a member here
    Apr 2006
    Sears (Craftsman)??
    Registered User andreb's Avatar
    Jun 2009
    De Forest, WI
    EMSimon, are you sure it is a T-24 size? I don't think it exists, only a T-25, T-30, T-35, T-40, T-45, T-50 or T-55 size are on BMW motorcycles. Regardless, you can go to Sears or Amazon to get anything you need.
    Andre Boening
    2010 F800GS and 2012 K1600GT
    Apr 2006
    Quote Originally Posted by andreb View Post
    I wasn't asking and the OP said M24. I have not seen a T-24 either. Just came back from Home Depot and they have all the Torx bit sizes you can think of.
    Riding for the SON
    Pasco Wa.
    Quote Originally Posted by 164809 View Post
    Thanks,
    Peter
    My bike has a 24 mm hex like nut for drain plug. If you have a torx female, I am sure it is larger that size 24. I wish mine was a female allen type. The hex, you have to be very careful to make sure the socked is square before loosening or tightening.
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    "24" has to be a typo, or it's some other type of head (Jack Bauer?). I've looked at Sears, Snap-On, and Home Despot, and no T24 bits.
    Maybe there's just a buildup of crapitation on the inside of the socket...? Solvent and a pick... Or maybe the OP is actually incorrect in that it's not a Torx, but an abused Allen.
    There are indeed oddball sizes available (T6, 8, 27, 47, 55; and external sockets in T12, 14, 16, 22, and 34; and mini-Torx for electronics), but I don't think we use them.
    Albuquerque, NM
    http://wihatools.com/indexes/indxtorx.htm
    Yes, there's no such thing as T24.
    There is E24 (external torx)
    http://wihatools.com/Marketing/torxspec.htm
    Kent Christensen
    21482
    This may or may not be helpful but the oil drain plug on my '13 F800GT uses a 10mm allen wrench.
