D
DEANCOX
I put this question at the end of the "fuel tank whoosh" thread because Dave mentione using a zinc chromate to treat a spot where he had some corrosion. But that wasn't the right place for it since it is a completely new subject.
I'm going through and completely tearing a K75C apart and cleaning it up. Most of the screws and bolts have some surface corrosion, especially the heads that have been exposed to the elements. They look fine once I clean them up with the wire wheel on my bench grinder.
They look nice now, but I'm sure they will rust easily. I live in LA so it won't happen fast, but rust never sleeps.
Is there a product I can use to put a new coating on them? I know I could just buy new bolts, and I think I will probably do that over time, replacing them with stainless steel. But I need to do someting now.
Any ideas? Is zinc chomate a solution? A little casual web research tells me it more like a paint and I do not want to paint most of them.
