Results 1 to 12 of 12
Thread: Brake -unable to pressurize or bleed '95 K75
    I have a 1995 k75 with 20k miles, with ABS. After noticing a leak from the master cylinder I removed it and honed it out with 0000 steel wool. Installed it and it seemed to be ok. I have been unable to bleed or pressurize the system even when using a Harbour Freight bleeder. At this point I think I've introduced air into the ABS. There is no pressure / resistance on the pedal. I was even thinking of getting rid of the ABS because I know it would probably be easier to get this brake going again. Is the lack of pressure due to a still bad master cylinder ?
    Should I buy a new master cylinder and try that and if that doesn't work then take it to a dealer.
    Any ideas?
    Last edited by deilenberger; 08-31-2013 at 04:46 PM. Reason: added year/model to title
    Don't buy anything yet.
    It sounds like air in the system is preventing the master cylinder from priming. Also, check pedal free play to make sure the piston is returning all the way. When I installed new brake lines it took me longer to bleed fill the system than it did to replace the lines. Once you get fluid flowing then just bleed at the modulator first, then bleed at the wheel caliper. Keep adequate fluid in the reservoir so you don't have to move a new bubble all the way through too.
    I favor a one-way check valve on my bleed hose, or a speed bleeder valve on the caliper. Then carefully pump the fluid through.
    Hi 48498 (Name?)
    Please see: http://forums.bmwmoa.org/showthread.php?46057 - I'm adding this info to your thread title.
    As far as your brakes - when you cleaned the cylinder - did you make sure the hole between the reservoir and the bore was clean? It isn't unknown for these go gum up - and if so, no fluid is going to get into the system. The condition of the brake hoses is also suspect at 18 years.. they've been known to collapse internally and look just fine on the exterior. Usually this failure allows fluid into the system, but doesn't allow for pressure relief when you release the brake, leading to dragging brakes. I believe Paul G has an article in an upcoming MOA Bench-Wrenching article all about brake lines.
    Also - did you replace the master cylinder piston/seals? Or just clean them up? 18 year old seals have a fair chance of being perished... As far as your question on buying a new cylinder - my experience has been about 50/50 with trying to rebuild master cylinders. Often when they fail - the bore has some corrosion in it down at the far end due to water buildup in the brake fluid. No amount of honing is going to fix this. Given those odds - and the PITA that a rebuild involves - if it's economically practical it would be a new cylinder for me.
    And don't eliminate the ABS. Have you bled the ABS modulator? If there is air in it - once you get the fluid flowing it should bleed just fine.
    A caution on bleeding - remember the corrosion in the bottom of the cylinder - often people bleeding the brakes will take a full stroke on the pump stroke of bleeding. This makes the piston go into areas that it has never been in, and the corrosion or pitting will damage the seals. Trick here - tape a block of wood about 1" thick to the lever or the grip (whatever works for you) to keep from going too deep on the in-stroke. That's assuming it's the front circuit we're talking about. If it's the rear - just be REAL careful not to fully depress the pedal.
    I have never heard of that but it makes good sense..Always good to read here..
    Brake 1995 K75
    I removed the dust cover from the rear master cylinder and discovered that the piston was stuck deep in the bore. I have to disassemble and determine the damage. I am now leaning towards buying a new master cylinder, a reservoir hose and clamps for the hose.
    I probably caused this by depressing the pedal causing the piston to go too far into the bore.
    I'm thinking of buying the master cylinder at boneyard.
    Where can I get the reservoir hose and clamps?
    What size clamps, FI type?
    Thank you all for all the info. I only wished I would have asked before venturing out on this task.
    I welcome any new thoughts on this matter.
    Bill
    1995 K75 Rear Brake
    I installed the rear master cylinder, new reservoir hose and new clamps. I used my Harbour Freight pump bleeder. I now have a soft pedal. I've heard it's impossible, on an ABS system, to get a firm pedal without taking it to a Dealer. Is that true? Where do I go from here. I have a syringe, can I reverse bleed? And if I can ,do I start at the ABS MODULATOR first and then the rear caliper? I also have but have not installed yet, Speed Bleeders.
    How do you adjust the adjuster in the rear master cylinder?
    Bill
    Ohio
    On my '93K11 I was not able to get a good pedal with the Myte-Vac system. I just used it to fill everything after changing to SS lines. Just went old school with using the pedal and a wrench on the bleeder. Have a firm pedal now. I bled out the abs first then went on to the caliper.
    Jeff
    93 K1100LT
    03 K1200GT gone but not forgotten
    14 Victory Crossroads
    Quote Originally Posted by 48498 View Post
    Bill
    Absolute pure balderdash! Over the years and 7 or 8 K75s I have installed new calipers, rebuilt calipers, installed new brake lines, installed a new master cylinder, and changed brake fluid an uncounted number of times. And I always achieved a firm pedal.
    The basics are simple. Use only DOT4 brake fluid. Fill the entire system with 100% brake fluid and 0% air. If the hoses and seals are sound you will have a firm pedal/lever.
    The front brake will gravity feed, even through the ABS unit. I always bleed first at the ABS modulator and then at the wheel caliper. Sometimes you will need to reposition the caliper so the bleed screw is pointing straight up to get that last little bubble to come out.
    Since we have several bikes (meaning lots of bleed screws) I use a one-way valve on my bleed hose instead of buying 20 or so Speed Bleeders.
    I don't use a vacuum bleeder because I can never tell when I am done. Little bubbles get drawn in around the bleed screw threads. However, vacuum is a good way to mostly fill a system when parts or lines have been replaced. But I would then finish up the old fashioned way - pump, pump, pump.
    Never use long, full strokes unless the master cylinder is brand spanking out of the box new. Crud or corrosion beyond the normal piston travel can shred or do lesser damage to the piston seal. Tape a wood block to the handgrip if necessary to keep the strokes shorter than normal travel.
    Pros do use vacuum sometimes. They open the bleed screw with a hose attached. which goes to a fresh container of new fluid. They use a fitting equipped reservoir top at the master cylinder. They apply vacuum to the fitting at the top and suck fluid in the bottom and out the top. This brings any air bubbles out the top with the fluid.
    I have never done it this way because we have too many different master cylinder types to try to make modified caps for.
    Apr 2012
    Los Angeles, CA
    Paul, what sort of one-way valve do you use on your bleed tube? I like and use the SpeedBleeders, but I can see the advantage in having this feature in the tube instead.
    2000 R1100RT / 1987 K75C (RIP) / Santa Clarita, CA
    Quote Originally Posted by JamesInCA View Post
    The one I have was called a "One Man Brake Bleeder" purchased at an auto parts store. It is just a small ball check valve on the end of a piece of vinyl hose. I needed a second one to keep at our son's in Kansas. So I just ordered a little check valve off the internet and put it on a piece of tubing.
    This is a good one:
    http://www.motosport.com/dirtbike/pr...FbFDMgod0g0ASA
    Apr 2012
    Los Angeles, CA
    This is a good one:
    Thanks! I've seen a plastic, kind of junky-looking "one-man brake bleeder" kit at the store, but it doesn't inspire confidence. The one at your link looks rather more substantial.
    Apr 2009
    Huntersville N.C.
    Whenever I replace all of the brake lines I backfill the system with a hose zip tied to the caliper bleeder & use a big syringe.
    Dave Selvig
    2004 Black LT
    2000 Canyon Red LT
