Have a look at the BMW document that shows how the coding plugs were meant to be used. (Although the RT isn't shown on this it is the same as the RS.) By comparing this and the parts list you can see that the R and GS share the same heads, cams and intake tubes.
So I'd say that no plug (which means ignore the O2 sensor and use a fixed fuel table for the RT/RS) is okay but a better plug would be Beige (30-87a). The beige plug says to the Motronic that your bike is an R1100R or an R1100GS and that it should ignore the O2 sensor--Open Loop fueling. When you run Open Loop configurations, the Moteonic looks for something called a CO Potentiometer which it measures to set idle Carbon Monoxide, and hence AFR settings.
I have measured a spark advance timing difference on the R1150RT (my bike) for the RT plug vs. the GS plug. So an educated guess would be that Spark Advance is more different between the coding plugs and fueling is more similar.
So my bottom line, if you like the way it runs, keep it as it is.
RB
Thanks!..well then I'll leave it as it is , as it runs fine. I [had] a surge , but TB balance cured that. @ the same time I checked the TPS reference signal / voltage and it was within spec. We do not have allot of E/10-15 gas here [S,Ohio] so I haven.t had to contend with that. And I really haven't encountered it much out traveling yet.
You're fortunate. In Massachusetts E10 is all we have ... And it leans out a "coding plugless" bike a lot.
I know it's more cost, but does a fuel additive help?
One reason I ask?...if the weather ever mellows out. I would like to travel up east [New England} maybe yet this year. Was up that way on 07, but the people I was with wanted to head home early... One reason I really prefer to travel alone...
You're not missing anything here now, cold and very rainy.
I'm not aware of an additive that would richen fuel with e10. It takes more (by weight) e10 fuel (compared with non-ethanol gasoline) to achieve a given air to fuel ratio--about 4% more.
When there is a functioning O2 sensor, the Motronic can figure out that it needs more fuel. On an r1100 when you select a coding plug (or don't have one) that tells the Motronic to ignore the O2 sensor it loses the ability to compensate for e10 (and other variations).
Check your front calipers by spinning the front wheel while on the center stand, if it does not spin freely you might have friction going on that can give the same sensation as surging. I'm currently going through hell with this exact issue.
My early 94RS has never surged. But it is an early RS which never had a CAT Code plug from stock. But here are some other aspects of the bike which may help:
1. I regularly run Techron through the fuel to keep it clean
2. Autolite 3923 plugs, inexpensive and really durable
3. Well balanced setup of valves, timing and throttle body balance
After I modded the exhaust, it leaned out the fuel mix enough to cause excessive exhaust "pop" (not backfiring, its never should be called backfiring) and some slight surging. So I installed a Techlusion and it cleared right back up. The bike runs smooth, no surging, clean/strong acceleration, mid 40's fuel mileage. So in my opinion the issue is all about getting the bike fuel system cleaned up, get it to run slightly more rich if it does not respond well to TB balance.
I do my own maintenance, so I have had some experience dealing with the problem. Once a year [usually around 12,000 miles.] , I clean the throttle bodies, adjust the valves, change the plugs and blow out the air cleaner. I am lucky enough to have ethanol free 93 octane available locally and never have the problem when running ethanol free gas. The problem has arisen while traveling when I cannot find ethanol free gasoline. But even then, it is not too bad. Of course, I ride in the higher RPM range. BMWs of any year do not like to be lugged around.
BMW's cure for the r1100 and r1150 is the R1200.
That's how I see it, as well. Like the OP, I had a machine that was untunable. I understand there are some around.
I had an R259 Techlusion box on my first 1996 R1100 RT. I had the older original model (top one) shown in the photo below.
I had several long chats with the support people at Dobeck Performance on what it does and how it works. Basically it lengthens the pulses to the injectors themselves. You only connect to one injector as they both go off at the same time.
When and how much is adjustable with four trimpots. I am really not sure what the O2 model did with the O2 sensor signal. My understanding from the Dobeck guys was it was used for reference and not modified. In any case, my 96 RT was a Euro model and had no O2 sensor anyway. The connector coming from the ECU was sealed off with a vinyl plug as there was nothing to connect to.
This was all over the phone and may have been hearsay or just what they wanted the customer to "know". I did not do any serious testing however it did improve the bike's performance somewhat. Did it completely cure surging? In a word, no.
