Results 1 to 15 of 19
Thread: Accessing coolant expansion tank area/removal of plastic panel
    Registered User HaroldGSW's Avatar
    Mar 2009
    Charleston, SC
    Does anyone have any suggestions regarding the removal of the plastic panel on the right side that gives access to the expansion tank and radiator fill? I successfully removed the necessary screws and pulled at the panel from above, but the lower contact point is resisting coming out--and I don't want to break anything this soon. Any meaningful suggestions will be greatly appreciated.
    Harold
    Quote Originally Posted by HaroldRT09 View Post
    What bike are you referring to?
    Mar 2009
    Charleston, SC
    The R1200GS water cooled--the newest, 2013 and only water cooled GS.
    Harold
    You're right. My mistake. I never looked to see what thread I was in. My bad. Apologies given.
    May 2008
    Racine, WI
    Quote Originally Posted by billy walker View Post
    ...I never looked to see what thread I was in...
    Typical behavior, sorry, couldn't resist the comment for such a prolific poster.
    Dick
    R1200GS '08
    "Hey, where you goin'?" "Nowhere in particular." "Man, I wish I was you." "Well, Hang in there..."
    Quote Originally Posted by rjzinc View Post
    You've got me there!
    Mar 2009
    Charleston, SC
    Thanks everyone--it's no big deal. I like to get ahead of the game in the event something goes wrong. I've learned that hard way not force any fitment on the bike, because everything normally fits well. In the meantime, it's another rainy day here in Charleston, so that means another GS day finding mud and such to play in--you gotta love this bike.
    Harold
    Harold, I looked at a parts book and having never seen the bike in real life I'm not sure which cover you're referring to. Covers that I did find seemed to be held on with either obvious-to-the-eye screws and/or rubber dampers. Why don't you visit Max and look for your cover and maybe that will help you in the removal.
    http://www.maxbmwmotorcycles.com/fiche/fiche.aspx
    Have fun muddin'!!
    Mar 2009
    Charleston, SC
    Thanks for the suggestions--good advice. And you have a good one, too.
    Harold
    Mar 2009
    Charleston, SC
    Okay, so here's the deal. I finally learned how to accomplish removing the panel on the right side of my wethead, which gives access to the radiator and expansion tank. There are four panel screws, two visible from the outside and two inside of the panel at the front of the bike. Additionally, is a plastic fastener that holds the lower part of the panel to the frame (that's the tricky one). Depress the center dimpled hole and gently pry it out with a flat head screw driver, or any other similar tool. Once that's done, the panel comes completely off giving free access to the aforementioned items.
    Harold
    Registered User Emoto's Avatar
    Jul 2003
    Boston
    This is great info! That little plastic b*stard baffled me, too, and since I didn't need to be in there, I left it for another day. So, to clarify, I depress the area in the center of the bolt head while at the same time lifting the head with something under it like a thin screwdriver?
    Eventual Master of the Obvious
    SE Mass - SOHC4 - DoD - BMWMOA - EMOTO #1
    Mar 2009
    Charleston, SC
    You are correct--had that explained to me by one of the BMW mechanics. It's always nice to know how to access things, and deal with issue that may arise while out in the boonies. Enjoy the ride
    Harold
    Jul 2003
    Boston
    Agreed, and thank you so much for posting this VERY useful info!
    Quote Originally Posted by EMOTO View Post
    I'm dense. I don't quite understand "press center of head one way while lifting the head the other way". This is a case where a picture might help.
    Like you, I haven't needed to get there yet so have ignored the issue. But next week I think will be "wire up electrical farkles" week and will probably need to have most of the plastic (and the tank?) off the bike to figure out my best routing.
    Sure do wish the reprom were available.
    Jul 2003
    Boston
    It is like a plastic nail with the center drilled out. A second piece lives in the area in the center that was drilled out, and when you push it in, it releases the claws on the outer piece. So, you lift it out as you push the center to release it.
