Results 1 to 6 of 6
Thread: replace fuel strip by float on 2005 R1200rt
    Can I replace the fuel strip on my r1200rt by a 2012 or 2013 float? What part shall order
    Registered User RT290's Avatar
    Mar 2012
    Sheboygan, WI
    Does it matter? I'm on my second float on my 2011 RT. It will be replaced shortly as it is failing after only 4000 miles. I honestly don't think it matters if you have a float or strip. Although, I'm the only person, to my knowledge, that has posted about a defective float.
    Joel
    Albuquerque, NM
    My 2012 RT with float system has 0.5 gallon less fuel capacity than my 2008 with strip. I assume a different tank and could check realoem to verify.
    Kent Christensen
    21482
    '12 R1200RT, '02 R1100S
    Spring Lake NJ, USA
    The quick answer is no.. even if you replaced the tank, the electronics on the bike wouldn't support a float assembly.
    BTW - useful info is the year of your bike.. helps in lots of cases to make a more accurate guess at an answer.
    Thanks for your input . I read a long and instructive thread on advrider. I think I will bypass the strip gauge . You are right about indicating the year of my bike . It is 2005
    Spring Lake NJ, USA
    Quote Originally Posted by tranzeat View Post
    Thanks. I'll add the year to the thread title..
