bobinthemtns
Okay...
So 1977 R100S, last week it started coughing and sputtering at speed..
Naturally I assumed it was time for a spring-time carb clean-out..
But squeaky clean carbs didn't correct the problem.. checked the air filter, valves.. nothing.
Then I remembered the adage I've seen posted here about the majority of carb problems being electrical.....
So popped off the front cover to check the points- when I run the motor watching the points, at about 3500-4000 rpm's the small spark you see on the points grew to what looked like a spiderweb of electricity covering the whole points area...... and (shocker!) when the arcing grew to that degree is when the motor would sputter....
So, bad condenser??
So, bad condenser??
