Results 1 to 9 of 9
Thread: Tire Pump
    Registered User bluehole's Avatar
    Oct 2005
    Midlothian, Virginia
    Tire Pump
    Any recommendations on a tire pump for an Airhead? Looks like the plug style pumps are the standard. I would prefer to buy one with the clips instead of performing plug to to clip surgery. Is some kind of compact tire pump an alternative? Space is at a premium so something not too bulky or heavy is a big plus.
    1972 R75/5
    1993 R100R
    Liaison 20774's Avatar
    I carry a good quality bicycle pump for just touching up the pressures on the road. I also carry an electrical pump that plugs into the battery with a cigarette lighter adapter. I bought one of the $15-20 DC pumps from Wally World and broke the plastic away to leave the important part of the pump. I carry it all in a small plastic pouch in my saddlebag.
    Apr 2006
    Options galore here, and a BMW rider owns it too.
    http://motopumps.com/inventory/pumpkits.htm
    2010 F800GS Full Ohlins package, '04 R1100S Replika
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Tuscany and Central Italy 2010
    Jun 2012
    Olympia, WA
    I use the $30 Slime 12v Pump too and it's worked great.
    Use it a few times in your driveway so you know it's all good before you really need it on the road somewhere. You'll need a pressure gauge too.
    TravelsWithBarley.com
    Jan 2009
    Craftsbury, Vermont
    I'm thinking of getting a bicycle pump, one with a locking clip and a built-in pressure gauge. Sure seems like less bother than a powered pump...I might actually use it on the road!
    '12 R1200GSA for solo rides
    '10 R1200GSA with Hannigan dual sport sidecar for rides with Tulliver
    http://travelswithbarley.com/
    Registered User Bob_M's Avatar
    Aug 2004
    Portland Oregon
    Those little pumps - 8-10" have such a small cylinder that you are making a lot of strokes to move any volume of air. I now carry a slime pump, and fiddled with the wiring so that it fits in the BMW power socket.
    Jan 2009
    Craftsbury, Vermont
    Quote Originally Posted by Bob_M View Post
    With a sidecar I have the option of carrying a full-sized version under the dog's bed.
    Wisconsin and Florida
    "I carry a good quality bicycle pump for just touching up the pressures on the road."
    THE MOST IMPORTANT WORD ABOVE IS "QUALITY"
    You only need about 12-15 lb to drive away safely to station air but a cheap plastic Walmart type pump can fail by getting so hot at the discharge end
    that the plastic melts and the hose blows out of its threaded hole. Also you can have a heart attack lying on the ground and trying to pump fast
    enough long enough to get the job done! Also the plastic pump if held on the bike frame with a rubber strap for a year or more will deform and
    no longer remain a cylinder preventing the piston from making useful stroke.
    These are all things I learned the hard way with some bitterness - I now use the slime pump - had it for 3 years and lots of miles - like a good luck
    charm - only needed it for an on road patch job once.
    Registered User stanley83's Avatar
    Oct 2009
    Somerville, MA
    My favorites
    My favorite bicycle pump is the Topeak Road Morph G. It has an aluminum barrel, a built in gauge and pumps like a floor pump. Filling high pressure road bike tires is never a problem. For MC use, I'd get their mountain bike model for it's higher volume per stroke.
    For an electric pump, I've been happy with the Cycle Pump
    Justin in Somerville, MA
    _________________________
    76 R75/6, 78 P200E, 63 VBB
    Lots of bicycles
