Would someone describe the two vent hoses connected to the fuel tank of my 2002 R1150RT. I've studied the canister removal thread and would rather understand the mechanics behind it before deciding how to proceed. Thanks.
The other side of the solenoid goes to the throttle bodies which are the source of vacuum to draw air through the canister, from the drain hose. This hose needs to be plugged somewhere, or disconnected at the throttle bodies which are then capped.
RB
I removed the canister and capped the throttle bodies. Do I need to do anything else to the solenoid? Cap it, unplug it ???
Glad to help. I go back and forth on this issue, why do you want to remove the canister?
