Results 1 to 12 of 12
Thread: 2009 R1200RT - Wunderlich Front Protection Bars
    Aug 2010
    Calgary, AB. Canada
    Good day!
    recently put a set of the BMW R1200RT front engine protection guards on my 2009 R12RT. Fairly straight forward, but after I installed them began to look at the clearance of the outer tips of the bars relevant to the stand off distance between the outer oil cover. It appears to be less and than 1". My question is, is that enough, as my BMW factory Airheads tip over bars really stick out. Has anyone had any experience in this matter? Or am I just being anal?
    Would anyone recommends the rear set of saddle bag protection bar as well from Wunderlich?
    Rick MacPherson
    1968 BSA Starfire, 1976 BMW R75/6, 1992 R100RT, 2009 R1200RT
    May 2011
    South Kentucky
    I have the Wunderlich engine guards and the rear guards on a 2008RT and they work well.
    Anthony S.
    2012 R1200GS
    Aug 2011
    North Coast of Ohio which sounds much better than Cleveland
    Wunderlich Rear Guards
    In my experience the rear guards do not work for 2 up riding. Installed a set and removed them after 1/2 a city block. Sold them at a loss on the Flea Market as Wunderlich has a no return policy.
    Aug 2010
    Calgary, AB. Canada
    Quote Originally Posted by sloride View Post
    Anthony, If they work well, is that from experience in dropping the bike, thus you had adequate protection from damaging the head valve covers?
    Rick MacPherson
    RAINEY 187132's Avatar
    Sep 2012
    Grand Rapids, MI
    Very good question. i'm now watching this thread because I was thinking about getting them too.
    Jason
    Grand rapids, MI
    2012 BMW R1200RT
    Central Ohio
    I had a near zero mph drop onto the right side, with the rear bags off the bike. The Wunderlich front bars allowed some scrapes toward the rear of the valve cover that would not have occurred if the bags had been mounted or if I had the Wunderlich rear bars. I filled the scrapes with epoxy and repainted the bars and valve cover - looks good as new.
    My feeling is that BMW should design tip over protection into the bike as Honda does with the ST. Tip overs are inevitable. There is no reason that expensive and critical parts should be left unprotected.
    Larry
    2006 R1200RT
    Sep 2012
    Grand Rapids, MI
    Quote Originally Posted by lkraus View Post
    I totally agree with your last line
    Jason
    Grand rapids, MI
    2012 BMW R1200RT
    May 2011
    South Kentucky
    Quote Originally Posted by b25bsaboy View Post
    My bike came with a few light scratches on the bags. I put the rear guards on and have dropped it in 0 mph situations and they worked. Also dropped the bike after putting the front guards on and they worked well. All these drops occured before I had the bike lowered with Wilber's shocks
    Anthony S.
    2012 R1200GS
    Aug 2010
    Calgary, AB. Canada
    +2 and should be a standard equipment item as the old Air Head front tip over bars were?
    Rick MacPherson
    Insatiable Cruiser rtwiz's Avatar
    Mar 2011
    Chicago Suburbs
    Good day!
    I have these bars. I dropped my bike turning it around on a gravel road in the middle of nowhere with them. The head covers still got scratched a little, but I didn't get a hole in them. You don't want the bars to stick out because it limits ground clearance for turns. Crash bars shouldn't contribute to a crash!!!
    I like these because you can adjust the valves and change oil without removing the bars. Several other kinds require a massive PITA procedure to get to the valves. You got the right ones!
    Central Ohio
    Quote Originally Posted by rtwiz View Post
    Good point. I've found that by pulling the top out slightly, and rotating toward the front (with care), I can even remove the lower fairing without removing the bars.
    Larry
    2006 R1200RT
    May 2011
    South Kentucky
    The wunderlick bars wont inhibit plastic removal
    The only time I've had to move the bars is when I changed the generator belt
    Anthony S.
    2012 R1200GS
