kwb210
Another fun tool!
Using the clutch centering tool makes life better. At least for the couple of minutes when you go to install the transmission! Nothing better than alignment, okay, nothing currently comes to mind. Use the tool as you insert the bolts to begin pressing the clutch assembly back into the flywheel, lots of pressure, do it carefully and with the correct bolts. Then the allens that will be placed are much easier to install to their 17 ft lbs.
