Results 1 to 12 of 12
Thread: brighter brake lite replacement?
    islandtime
    I thought i found a site a while back that had a replacement kit to add 2 additional bulbs to the brake light of my('95)k75.. Anyone have a link or know if this is still available.. If not I think i am going with the led replacement..Any one have experience with either one?
    thanks for the help
    Gene (islandtime)
    Blocking the slow lane
    Edwardsville, IL
    This is the one we use: http://www.run-n-lites.com/K-T-2.asp
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    sportridertex
    Lights
    take a look at this site for LED light info.
    http://www.webbikeworld.com/lights/
    Rally Rat paulsibek's Avatar
    Apr 2004
    near Los Angeles
    I use
    a Kissan tail light modulator with great success. Can't miss it.
    ERIC1514
    Brake Light Replacement.
    Hi All,
    When you do any of these brake light mods, does it mess with the bulb check feature of the instrument cluster?
    TIA,
    Eric
    Apr 2004
    near Los Angeles
    Yes
    On mine it puts the red light on the dash on all the time. When you apply the brakes it then flashes like the modulator.
    The dealer said this was typical and no problem so I put a piece of velcro over it so I can only see it a night.
    State of Confusion
    I use hyperlights and am really happy with them.
    -=Brad
    RIDERR1150GSADV
    Talking
    I have the Backoff dual LED license plate frame and the Kisan brakelight modulator . I believe that is about all you can add to the latest generation ABS powered brakelights without it throwing a hissyfit
    CustomSarge
    Post
    To satisfy the bulb minder, put a 10-15 ohm 15 watt resistor in parallel to LEDs. Put it where the heat won't melt anything. The minder works on load & LEDs aren't much.
    Adding lighting/loads to the new bikes requires a relay of some kind that is isolated from the system. I prefer solid state types because they draw 10 odd mA of load themselves, not enough to set any engine codes. Good Hunting... <<<)))
    ERIC1514
    Electrical Ignoramus
    CustomSarge,
    When you say wire a resistor in parallel, does that mean, in simple terms, to cut the wire going back to the taillight and splice in the resistor?
    TIA,
    Eric
    West Salem, OH
    Quote Originally Posted by Eric1514
    CustomSarge,
    TIA,
    Eric
    When you cut the wire and put in betwen the ends, that is in series. When you just attach it along the wire it is in parallel.
    Gale Smith
    2009 Versys
    1999 R1100RT
    CustomSarge
    Load in parallel
    Use the same two connections as your LED unit does. BMW Ks use brown & grey/yellow for brake light. GH... <<<)))
