jchildress
If you don't have one of these do yourself a favour and head over to Harbour Freight and pick one up. http://www.harborfreight.com/micro-torch-60645.html
They work much better than a heat gun for pin point heating and are refillable with butane. Used to heat any bolts that have loctite on them especially when the area has painted surfaces around the bolts. Heat the center for about 2 minutes. A bit more for larger bolts. This will soften the loctite enough to get them out easily and without galling threads. Do not force the bolts to turn out. Use more heat if they don't turn easily once you get the initial torque off them.
Thanks Happy - Yes I do have one (for creme brulee !) and could try. Could I also use the heat gun with the concentrator tip ? If I do what temperature should I set the heat gun on ? Maximum ?
