36654
Just the liberal media - makes for flashy headlines.
You should look at the other stories on the goerie.com website. They seemed awfully excited about their interview with Glenn Beck.......
moderator , where are you?
You can find the most detailed data on that statistic in the European "MAIDS" study; which is a recent in-depth study of motorcycle accidents: You can access the data tables here: http://www.maids-study.eu/data_tables.html (You may have to create an account to log into the actual crash study pages).
However, these are stats based on the European riding environment, so the data may or may not be valid for the U.S.
DOT studies say about 27 percent of motorcycle operators killed in crashes were speeding. (Source: http://www-nrd.nhtsa.dot.gov/Pubs/810834.PDF)
I do a lot safety-related work and research in the industry, so here are some more stats to think about:
- The most common location for crashes involving a motorcycle and another motor vehicle (4 or more wheels) is at intersections. The usual scenario is the other vehicle turning left into the motorcyclist's right-of-way. We probably all know this one... (Source: MSF)
- Here's one you may not know. Approximately 40% of all motorcycle fatalities occur because the bike ran off the road. The most common location for this is in a curve/corner. The usual culprit: too much speed. (Source: MSF)
- According to another recent European study, if you do crash, the chances are 62.8% that your initial head impact will occur somewhere in the front or side facial region.The study goes on to say 34.6% of those total first impacts will be in the chin bar area. Kind of makes a point when you think about how many riders wear open (3/4) helmets or less, doesn't it?. (Source: http://trid.trb.org/view.aspx?id=1124566)
There are lots of other, sobering statistics out there and a little research will find them. Do some reading and you won't get on a bike again without ATGATT.
okay. if you read his entire quote, you realize what Cook is actually saying, which is that above 30 mph you're most likely to die from internal injuries, rathe than a head injury. given the number of potential objects one can hit, get impaled on, slammed against.. it kinda makes sense. cherry-picking his quote to sound like he is saying "don't bother with a helmet" is really pretty lame- the guy sounds like he is actually more of an anti-motorcycle guy than an anti-helmet guy. quoting someone out of context sure changes the meaning, doesn't it?
Now where did this coroner say that if you are going above 30mph and you are in an accident it is SAFER NOT TO WEAR A HELMET?
All I got from it was that above 30 mph there is no guaranteed safety from wearing a helmet...which sounds reasonable to me.
/Guenther
If the stars align wrong, you're gonna die or least be injured.
This begs the question; at what speed do most motorcycle accidents happen ?
T
Seriously, it would seem that helmet issues aren't exactly a political discussion.
Here in Wisconsin, the percentage of "running off the road in a curve" incidents is even higher than 40%, with a frequent dose of alcohol mixed in as well. We have our own 'demons' to work on reducing here in the Badger State.
I would suggest there is no "guaranteed" safety at any speed.. If the stars align wrong, you're gonna die or least be injured.
