Results 1 to 9 of 9
Thread: Hazard lights?
    Stressed Member jmerlino's Avatar
    Jul 2004
    Boston, MA
    Hazard lights?
    One thing I've always wanted on my bikes is hazard lights. Basically, having all four turn signal lights flashing at once. Some newer bikes I've seen have 'em.
    This can't be a hard mod. All one would need to do, I would think, is just find a way to activate both turn signals simultaneously. I could add a switch to the handlebars - that's no problem.
    So... anybody ever done this? Got maybe a link to a site with a diagram or description? Ideas?
    --Joe Merlino - Modified '82 R100RT
    Registered User kioolt's Avatar
    Maryland
    I believe that BMW sells a kit for the airheads that will do what you want. It's probably a plug and play kit.
    2004 R1150RT 186,800 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 422,400 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Jul 2004
    Boston, MA
    Hm. Nothing on the Sierra BMW site. You wouldn't happen to have a link, would you?
    Maryland
    I got the following part number from the ETK for a 82 R100RT.
    61 31 1 243 590
    INSTALLING SET HAZARD WARNING
    The diagram shows a switch, relay, diode, wiring harness and assorted mounting hardware.
    AMA,BMWRA,BMWMOA
    Jul 2004
    Boston, MA
    Thanks. I'll look into it.
    Albuquerque, NM
    The BMW kit is best.
    It has the following feature, which you really need.
    Ignition must be on to activate 4-way flashers. It can then be turned off, and flashers will still work.
    Flashers cannot be activated with ignition off. (saves your battery from vandals)
    This requires a diode in the system.
    This is a kit that may become NLA. Check Motobins among others.
    Kent Christensen
    21482
    Apr 2004
    Howell MI
    I installed a switch that shorted the left and right turn signals together when I wanted four-way flashers. Did this on the R69S, 74 R90/6, 78 R100/7. Need to do it on the recently purchased 91 R100RT. Have never needed to replace a flasher.
    Jul 2004
    Boston, MA
    Quote Originally Posted by Ray Melosh
    This sounds like exactly what I'm after. Can you elaborate? Does the switch go before or after the turn signal switch?
    Registered User jhelming's Avatar
    Apr 2004
    Ledyard, CT
    Quote Originally Posted by kioolt
    I purchased the OEM BMW kit from Bob's BMW in Maryland three years ago and highly recommend it. It includes a diode, a second relay, wiring harness and instructions and is completely plug and play. On my RT there's even a blank hole in the relay board under the tank for the new relay. The switch replaces the blank in the center of the plastic handlebar cover -- all very slick.
    John Helming
    '91 R100RT ('Purpurfarben')
    '74 Duc 750 Sport ('The Yellow Peril')
