Spinakr
Current Mileage, 28,598
Several months ago I performed the Valve Adjustment as described in the HEXHEAD Tech section. Used .30mm gauges for exhaust and .15mm gauge for the intakes. All went well and I double checked my work. Ever since, I have noticed a pronounced tick from the left cylinder. So, I purchased the VonBaden video and METICULOUSLY performed the procedure again, literally following Jim's video step by step; Including checking the rocker arm endplay.
The tick is still there...
Is this normal?
Any thoughts are much appreciated
Is this normal?
