More valve chatter with Camhead than Hex?
glenfiddich
TravelsWithBarley.com
Under load, like when accelerating out of an uphill curve in second gear, I get a noticeable amount of valve chatter on my 2010 GSA. Not pinging, and not really loud, but pretty persistent from 2500 to 3500 rpm. Granted this is a sidecar rig and has to pull more weight than other bikes, and loses more speed in twisties than a two wheeler, but my 2007 GS never did this when the hack was on that bike.
Took it to the dealer yesterday and a master tech said the valve adjustment was spot on, but the rocker was a tad loose. He corrected that. But on the ride home thru the hills the chatter was undiminished.
Fresh oil and filter, 93 octane ethanol-free gas. Is the camhead just more sensitive to lugging than the hexhead..?
I don't know about the camhead but my 08RT would much rather be in first gear on a uphill curve at 2500-3500 rpm even with one passenger and no gear loaded
Sounds odd to me. Under load, the valves train should not be much or any louder.
I only had an oil head then cam head no hex head.
Sometimes I can hear a slight metallic sound not very loud coming from the valve covers. I just decided its the sound my bike makes. Its not loud, its not rattly like my air head, its just "busy" and barely detectable.
On my last trip with the girlfriend and all her (our) stuff on the bike, I was pulling a hill behind a pick up truck on a back country road in 6th gear 2200 rpm. Twist the throttle and away it went. No excessive noises at all. Valves were quiet as always.
So I am not hearing it on my 12 cam head.
David
Okay, but my point is my 07 Hex pulled without protest. Seems like the newer engine doesn't tolerate low RPMs as well, something I've been trying in order to minimize the loudness of the exhaust when riding with my dog. Barley clearly is not a fan of louder pipes.
Your post made me think.
Today I filled the bike with 89 octane. It was louder and more noise coming from the engine when lugging it or when I quickly cranked the throttle at low RPM.
With the 89 I hear a ping or two, and still some noise from combustion after the computer backs the timing off because of the knock sensor.
With 93 I hear nothing.
Bike will get 93 from now on. Its a 12 with 3300 miles. I have had it 4 weeks.
12:1 compression, I expect it to only burn 93.
