Somewhere i read a thread and details on modifying fill neck in gas tank to make it easier to fill but cant find it and have done searches. Can anyone help ?
The downside to this mod is that it can result in dumping gas into the charcoal canister, turning the charcoal into a slurry and blocking the tank's vent path.On the 1100s, you can delete the "anti-spill" flapper inside the filler neck just by unbolting it; this gets you a little more capacity & makes filling easier.
On the 1150s, you can drill a couple of holes around the top of the filler neck; this gives the air displaced as you fill an easier escape path, making filling easier. I don't think it gives you more capacity, and the tank should be disassembled to do this (or you get hot metal chips inside, not to mention sparks during drilling!).
Members - more details?
