deilenberger
A bozo on the bus
Jeff,
I was puzzling what would cause a chirping noise if the tank went under vacuum. A vacuum would pull the cap seals closed even tighter, so I doubt if that would be it..
Then a thought came to me (always dangerous..) - the high-pressure blowoff on the fuel pump is looking at "differential pressure" - ie - the difference between the input pressure and output pressure. When that differential pressure exceeds the force of the spring holding the blowoff closed, it opens and relieves output pressure.
In this case - the input pressure is the pressure in the tank. If your vent is clogged up and you're pulling a vacuum on the tank, that means the input pressure is negative, so the blowoff will start opening at a lower output pressure. Combine that with a partly plugged fuel filter - and it becomes obvious to me what is happening.
I suspect you'll be happy once you get your ride in
