well it happened again second fuel strip in three weeks! i have a call to bmw motorad to see what they have to say if anything.... sure seems they could have come up with a upgrade by now!
Sorry to hear about your strip troubles, we all share your frustrations with this plague.
If you look at the parts phish on Max BMW it indicates the new 1200 gs have a float now in lieu of the strip
We can hope BMW will recall all strips and replace then with a float that works.
2008 R 1200R replaced 7 fuel strips in less than two years, 2008 r1200 gs two strips in 4 months?
Good luck
Dave
Actually - I suspect this is a case of "dealer babble.." caused by the need to sound EXPERT when asked questions, most frequently happens with salespeople, but service personel are not immune. It's also known as talking out their as*es.. Despite what some people say, I've observed it appears to be a much less frequent occurance on bikes made prior to about late 2006, and it happens in countries where there is no ethenol in their fuel. If it was ONLY the midwest, what explains the 4 strips I've had on my R12R? It's never been west of West Virginia..service maanger told me that bmw has told him it is something to do with fuel mixture in the midwest! denver area for example has no trouble,not sure but think bmw is blowing smoke.....
Fuel doesn't contact what breaks.
There are no "fine wires" in the device. It consists of a clear plastic strip with vacuum evaporated metal patterns on both sides of it, that terminates in an epoxy block where the patterns are connected to standard wires that go to a junction plug. The plastic strip is held quite securely inside a plastic housing, and in looking at a number of failed ones - there was no physical damage to the strip.Fine wires are delicate. Excessive vibration or flexing might be a problem. Improper installation might pinch or stretch? If some dealers have more replacement failures than other dealers, I'd wonder about installer procedures.
I suppose even shipping stress may hurt them? Must be something else...
