Results 1 to 8 of 8
Thread: RT Headlight Bulb Replacement
    bikerboy108
    Nov 2006
    North Jersey
    Smile RT Headlight Bulb Replacement
    Read all the posts on replacing the front headlight bulbs on the 1200 RT and thought it was another way BMW was getting back at us!!
    Ok here is my 2 cents with the help of my buddy Bernie... Read all these posts and can't figure how this could be done without at least pulling off the trim panels ( 5 screws 5 min.) but maybe with this method you can... Got a 1 foot length of clear plastic tubing 1/2 inch id...It slips over the two tabs at the back of the bulb and supports the bulb nicely as yo move it into posistion. ( of course with TAB up) I then took my long 12" thin screwdriver I held the bulb in place, pulled off the tubing pulled down the two clips with my stubby finger s . Connected the back plug checked the lites and then screwed on the plastic cover...
    Sep 2003
    Virginia Beach
    I found the trick, for me, at least. Bike on center stand. Handle bar to the side - can't remember which side, but one side affords better clearance to get the hand in their and remover the access cover. Remove terminal, unhook bulb, then place new bulb in position as best as possible - from the FRONT of the bike kneeling down, and coming from underneath the fairing. Then, I got back up behind the bars and clipped the bulb in. I couldn't get it perfectly straight, but when I pushed the terminal on, in popped in straight and true. Button up and the job is done. I talked to the dealer, and, with a bit of experience, they said the job was estimated to be 12 minutes, by the book. Next time, it should only take me 20 minutes, not a couple of hours of frustration.
    Virginia Beach
    current:16 R1200R 75 R60/6
    past: 14 R1200RT 11 R1200RT 10 R1200RT 03 R1200CLC
    bikerboy108
    Nov 2006
    North Jersey
    the 12 " 1/2" id tubing takes all the angst out ofit just place it on the end put in posistion and clip it in done 2 min.
    Albuquerque, NM
    Tubing is great solution, although maybe only required for one of the bulbs. If you're right-handed, the right low beam (brake side). This I saved 'til last last time, so perhaps next time will use tubing on the others.
    Kent Christensen
    21482
    Dec 2010
    Boston
    My method in go down on one knee and reach up to the light from below. XXXL paws and it's almost a breeze.
    Apr 2010
    Mission, TX
    I just replaced both bulbs on a friend's RT while on a long tour. About 2 days apart. Took minutes to do.
    I stand facing the front of the bike on whatever side I'm working on. Handle bar is turned to the side being replaced. Clutch side is easier to replace for me. I look into the front of the lens while holding the bulb to make sure the new bulb is properly aligned. Next, while holding the blub in place drop the bail and lock by moving the wire from outside to inside. Do the same with the other side of the bail. Connect the two wire plug. Test light. If good, replace the dust cover.
    The trick is knowing how the bail locks and unlocks. That's 80% of the battle.
    tsp
    Blog: http://www.swriding.blogspot.com
    Mar 2011
    Lawrenceville,ga
    I have only had to replace the bulb once. I tried in vain to do it by working from inside the fairing, but my short stubby fingers were not long enough. I was able to get one of my riding buddies who has hands with surgeon like dexterity to replace it for me. He reached up under the fairing and was able to manouver his hand around to get everything locked properly back in place. My cost for this was to treat him to a barbecue dinner. Not a bad deal.
    neanderssance man sedanman's Avatar
    Jul 2011
    Pawling NY
    Just before Americade, I put HID's in mt RT. I took the plastic off to give mire room to run wires and place the modules. When one of the lights failed before I got to Lake George, I put my H7's back in on under an overpass in the rain. Only took a few minutes to remove the HID's and swap the bulbs back.
    Paul
    Stop wrestling with your motorcycle, dance with it.
    2011 R1200RT Traded
    2014 R1200RT fully optioned
