Hi all, just picked up a 1963 R69s, dover white, the one IÔÇÖve been looking for all my life. Fully restored, and less than 3 miles from my house. Even sold my R50/2 to pay for it.
Im afraid Im paying for it now
Runs fine, but in 4th it develops a knock about 50% of the time. IÔÇÖm not going nuts speed wise, about 60 or so. I can get that knock in 3rd sometimes, and it seems to happen more under load. I can sometimes get it at idle. I was able to videotape it in idle in case anyone wants to listen.
I can feel that knock, and I noticed that when I killed the motor at a stop (the idle needs to be upped), after a session of the knock, it had barfed up some oil out of the oil fill and the breather tube.
The motor seems to run fine, the clutch seems to be fine, but IÔÇÖm afraid of what it could be.
The only thing I can think of is that I should probably adjust the valves, but it isnÔÇÖt a ÔÇ£tappetyÔÇØ kind of noise.
On top of all this, I was wiping the oil off, and then found a tiny bearing, clean as a whistle, on the shift lever, just stuck there (like magnetically). Looked about the size of the bearing on the clutch throwout bearing that has about 6 bearings in that little disc-shaped retainer. But I canÔÇÖt say IÔÇÖve had a problem with the clutch.
To boot, itÔÇÖs a bear to start with the kickstart, particularly when itÔÇÖs hot. IÔÇÖve got to 2x check the magneto per VechÔÇÖs article, but I also see that it has the ÔÇ£modernÔÇØ plug caps, and not the brown ones.
Can anyone talk me of the ledge here?
