Results 1 to 3 of 3
Thread: Replaced Starter Relay
    Registered User JB1982RT's Avatar
    Jul 2003
    South Carolina
    Replaced Starter Relay on 1982 R100RT Purchased in April
    Attached pic of old one...Really Corroded.
    I sprayed connector with Contact Cleaner and also pulled plug off ECU & did same.
    Applied light coat of Dielectric Grease.
    WOW!!
    The indicator lights are so much brighter I can't believe it.
    If you have not checked this area for crud recently. I recommend it.
    Grammarian no, Rider yes ISAMEMON's Avatar
    Jun 2006
    Kings Valley Oregon
    did you stop there, with the tank off checking one realy and cleaning, I would have taken the time to clean em all, every connection I could find
    Jul 2003
    South Carolina
    I did do the wires on the coils.
    Anxious to get out for a good test ride yesterday.
    I will take your advice and go back in again today for a final check.
