Results 1 to 3 of 3
Thread: Safety clutch switch on r1200gs
    Striper55
    Dec 2009
    York Maine
    On my 2006 gs I sometimes cannot start it in first gear with the clutch depressed. Is it the safety switch or could it be the battery holding a low charge? Thanks
    It could be the switch. On my '05 the switch was adjusted such that I had to pull the clutch all the way to the bar. The clutch was disengaged long before the switch would change state. Before I realized what was going on I wound up replacing a battery.
    Short story: a GS-911 will tell you if/when the switch is activated. http://www.snafu.org/pics/r1200gs/20...clutch-switch/ has the complete story.
    Nov 2011
    Central Ohio
    My '06 RT will not start in gear if I pull the clutch lever before turning the ignition on. If I then release, then squeeze the lever again it will start.
    I try to remember to turn the ignition on before pulling the lever.
    Maybe this is a safety feature to ensure we have BOTH hands on the handlebars when starting in gear?
    Larry
