Results 1 to 8 of 8
Thread: '87 K75s / Magura Clutch Cable Replacement Barrell (Nipple Holder)
    Registered User kentuvman's Avatar
    Jun 2007
    Minneapolis, MN
    Hi Everyone and Happy July 4th!
    I've read about a small barrel falling out when a clutch cable breaks.
    Bought a spare cable last year from Motobins and haven't had to use it yet - just insurance.
    Beemer Boneyard sells this:
    http://www.beemerboneyard.com/magclcblbr.html
    Interesting enough, when I look where the clutch cable connects to the hand lever, I'm not seeing this piece in there - the cable works fine and is not frayed and has some grease on it
    Can I continue to run w/out this or is it something I should carry with the spare cable?
    Thanks much
    Ken
    Apr 2008
    SW Ohio
    You have one. Pull you clutch in and look at the inside end of the handle that's usually covered by the shrouding. The quarter inch round thing is the barrel, the end of the cable slips in it. Keep it well lubed.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Jun 2007
    Minneapolis, MN
    Thanks - you're right - it's there.
    The spare cable also came with a barrel - I should be all set and hopefully won't have to use it!
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Quote Originally Posted by kentuvman View Post
    The cable only comes with the barrel for the tranny end, not the barrel for the lever end. You need to carry the one for the lever end if you carry a spare cable.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    It's a way of life! oldnslow's Avatar
    Oct 2011
    Ash Grove, MO
    I learned the hard way!!
    Mike Davis
    "Old n Slow" It's a way of life!
    1985 K100RT
    1998 R1100RT
    Jun 2007
    Minneapolis, MN
    Anyone know the know the BMW p/n?
    I'm ordering a few airhead parts from the local dealer & will add the barrel too.
    Mar 2008
    Belton Tx
    anyone know the know the bmw p/n?
    32721233550
    Ron
    91 K75RT ABS
    Jun 2007
    Minneapolis, MN
    Thank You!
