Results 1 to 6 of 6
Thread: Rear shock preload adjuster
    St Charles MO
    Also; does anyone know a of a source for the copper (could be aluminum, I guess) seals on the rear shock adjuster flex line? Mine has been leaking slowly for a long time, but seems to be getting progressivly worse.
    I think there are two on each end of the flex line; at the shock and at the adjuster knob. A common banjo fitting, but they're not the same size as the ones on the brake lines, which are bigger. I measured one once and can't remember what size it is. Either 6 or 8MM on the ID and 10 or so OD.
    None of the parts fiches that I've seen show these as a separate part.
    Dum vivimus vivamus ted's Avatar
    What model and year bike? Aftermarket shock? Pics? All that helps
    Ted
    "A good stick is a good reason"
    1994 K75RT
    Moto Pages
    Spring Lake NJ, USA
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    The crush washers for the magnesium Bilstein triple adjust remote hydraulic preload argon filled shock with dual reservoirs on the rear of your '86 K75C can be purchased straight from Bilstein AG :
    ThyssenKrupp Bilstein Tuning GmbH
    Milsper Stra?e 214
    58256 Ennepetal
    Germany
    That's not what you've got????
    Damn crystal ball is screwing up again!
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    If this is for the K1200LT in your profile, try giving Bruno a call:
    http://www.brunos.us
    They have a great reputation n the BMW community, and rebuild BMW shocks.
    Ted
    1994 K75RT
    Moto Pages
    St Charles MO
    Talking K1200 shock adjuster
    Wow.....must be losin my grip...
    it's a 2000 K1200LT. My guess is all of 'em with this type of preload setup use the same size flex hose and seals. I could be wrong. I was wrong once before. ( I thought I made a mistake, but I didn't)
    Anyway, tnx for the info.
