After inital start and blinking light go off I drive a short distance less than a mile and both light start blinking. If I shut bike off and re start I am good for the day no mater how many times I start and stop. Any Ideas
What year LT ?. I'm guessing a 2002 to a 2004
The RS and LT are pretty similar, so I will take a guess that it might be the gap between the ring and pickup is not adjusted properly or you may have a low fluid level in one or your master cylinders?
Agreed that this is a reasonable assumption. NTL, get it sorted out as your brakes aren't working as they should. And brake failure could take the shine off your day.
thank you for responding I will take a look at this the breaks seem to be working fine
you got it a 2002
