Results 1 to 7 of 7
Thread: Larger rear tire on /5?
    Registered User robertklee's Avatar
    Mar 2006
    Tennessee
    What is the widest tire that will comfortably fit on a /5?
    Thanks.
    RKL
    "Leave the gun. Take the cannoli."
    Aug 2003
    Marion,Ar.
    4:00 x 18
    Polarbear Polarbear's Avatar
    Clovis,CA
    110mm
    I did a 120mm a while and it was very tight fit, rubbing the swingarm a tad. I run a 110mm rear Dunlop404 on my R100/7 today, nice fit. Same as your /5 in shape and basics back there. Randy
    Dec 2007
    Reno, NV
    Stick with the 400x18. Other sizes negatively impact handling, sidestand park angle, rub swingarm.
    Northern Front Range, CO
    why do you want to go with a larger/wider tire- what are you hoping to achieve?
    Ride Safe, Ride Lots
    Clovis,CA
    Check 'ON article this month:)
    This very topic comes up in "Keep em Flying", by Mr.Parkhouse. 110mm and 4.00, same size. Don't go bigger. Lots of folk, including me did the 120mm thing for a few years to no real advantage. Looked better perhaps and made the rear tire hard to remove come tire day service,etc....Randy
    Liaison 20774's Avatar
    Randy -
    110mm converts to 4.33 inches, so not really the same size. Even with that, one tire maker's 110mm may not be the same as another maker's. Heck, even 4.00 is not the unverisal value among manufacturers of that tire...it varies too.
    The big thing is really the profile. The metric tires are not as tall. This affects a number of things as previously mentioned. I found that metric tires front and rear dropped my bike a good 0.5 inches. Really messed with the /7 sidestand functionality. I'm back on inch-size tires, and I'm a happy camper again.
