I have a 2012 G650GS. Since I brought it home it has had a problem starting when it was warmed up, occasionally not starting at all until it cools off,(it acts like a bad battery). It's been to the shop twice now for this problem. The first time they said it was a loose wire on the negative terminal on the battery. The second time they said it was the stator and regulator.
After the first trip to the shop I warmed up the bike, took the seat off and put my meter on the battery. I then hit the start button and watched the meter. It started out with 13.7 volts, but when I hit the button it went down to about 7 volts. After doing this several times it finally started.
This sounds to me like a bad battery or starter, any ideas?
