b25bsaboy
With my on going issues with the spongy brakes I believe I will be having to rebuild the master cylinder. Further inspection and reading what I can, I fail to see if the master cylinder body is a seperate part of the control lever or is it all one piece. If it is separate, can it be serviced leaving the twist throttle in place on the handlebar.
Has anyone documented with pictures how to take this apart, inspect and do a reassembly of the unit?
