reimerdavid
Does the front wheel have to be removed to remove the entire front fender ?
Hi there, you'll have a better chance on an answer if you can edit your post with the year and model information. After that I can change your title to make it easier for someone to see, for example, Front Fender removal '09GSA. Good luck. GaryDoes the front wheel have to be removed to remove the entire front fender ?
