Results 1 to 10 of 10
Thread: Sticky throttle when heated grips on 'high'
    Riding Dutchman jacco's Avatar
    Mar 2005
    Kensington, MD
    Dear all,
    When I used my heated grips last winter the throttle got noticably sticky, especially when on 'high'. I would have to manually twist the grip to close the throttle after using them for as little as 5 minutes. Any suggestions as to where I should start if I want to try to fix this?
    Have a good weekend,
    jacco
    BklynPete
    do you have a throttlemeister? i have one and it is the cause of the friction with the heated grips on. i just back off the throttlemeister and all is well.
    pete
    Mar 2005
    Kensington, MD
    Thanks for the suggestion Pete, but no, the bike doesn't have a throttlemeister or similar friction based-cruise control...
    Best,
    Jacco
    Loading the Bike dschulze's Avatar
    Feb 2004
    Anchorage, AK
    Sticky Throttle
    I have the same problem. '01 1150gs, Pro Taper bars, Throttlemeister, about 34k on the bike. I went through, checked everything I could and finally found that my upper throttle cable was ever so slightly sticky. I cleaned out the Bowden box, put dry slide on the pivot and all is well!
    Ride Safe, Dennis
    Mar 2005
    Kensington, MD
    Quote Originally Posted by Crush
    Ride Safe, Dennis
    OK, that's a good starting point, thanks!
    How is it to drive with a throttlemeister, anyway? I know that I found this sticky throttle scary to drive with in town, but then again, my wrist was killing me last Sunday when I went on a 350-mile trip to Shenandoah.
    Best,
    jacco
    Feb 2004
    Anchorage, AK
    The difference between a sticky throttle and the Throttlemeister is that you can loosen the Throttlemeister, the sticky throttle is unpredictable. I only use mine when I am on the highway and there is no other traffic around. It sure helps my wrist.
    Ride Safe, Dennis
    ktmridin
    I had the same problem, the grip expands when heated . Just remove bar end and place a thin washer between the barend and the bar.
    Mar 2005
    Kensington, MD
    Quote Originally Posted by ktmridin
    OK, will try that. Maybe a good reason to buy that throttlemeister. By the way: Welcome! It seems that I'm the proud recipient of your first post .
    Thanks,
    Jacco
    rdsmith3
    I did the same thing as ktmridin -- I inserted a small washer inside the bar end so that there would be a bit more space between the right edge of the rubber grip and the bar end. That cured the problem.
    I assume that the rubber grip expands slightly when heated -- just enough to make it rub against the bar end.
    Bob
    SNC1923
    Let me preface this reply with the admission that I am not at all mechanically inclined.
    I just bought a throttlemeister for my '04RT (w/ heated grips) and really dig it. Tried it last night for the first time.
    When I first installed them, the throttle stuck. After rereading the directions, I realized I had to partially disassemble the throttle assembly (3 screws). Afther that, there is a small screw (4mm torx or allen) that you loosen to move the assembly away from the bar end (ever so slightly). Then the throttlemeister worked perfectly.
    I haven't tried it yet with the grips heated, but it's supposed to work. We'll see. . . .
    Perhaps you should try to adjust your throttle assembly? Maybe that will solve the sticking problem on "high."
