Results 1 to 10 of 10
Thread: 03 k1200GT fuel filter
Hybrid View
    Ohio
    Ok, another maintenance question. Manual says to remove the fuel tank and take everything out the bottom to replace the fuel filter. On my K11 I just reach in and replace it from the top after removing the fuel filler/cap. Is it possible to do this on the K12GT or is the opening just to small.
    Thanks,
    Jeff
    93 K1100LT
    03 K1200GT gone but not forgotten
    14 Victory Crossroads
    The access for the fuel filter (and pump) is through the right bottom of the tank. It's a PITA, and the only way to get to it.
    Jun 2007
    Exactly, totally different construction of the tank and filter assembly. Once you get in there - get the filter and pump out - you will likely want to change to screw clamps on the hoses as the stock ones are the factory crimped kind. There are at least two types of tank bodies providing for two different pump/filter 'covers'. One has several hex nuts around the large unit, others like mine, have a large screw on 'cap' with a rubber seal. It has been a long while since I did this myself but I seem to remember very good instructions in the Clymer manual, probably in the DIY section here, on the i-BMW forum, and also at Finley's Pirate's Lair. They all remind you to have a fire extinquisher handy, drain the fuel completely first, as this is of course the lowest point of the tank, etc, etc.
    The filter is on a hose that comes in from the 'outside' then goes to the pump. It is way down on the right, you could never get to it through the filler hole let alone get the necessary tools to it or see what is happening.
    While you are there, change your air filter. It resides under the tank.
    Jim Douglas '00 K1200RS >138,000 miles -- Black, 01/10/2000 to present
    Gone: White '09 K1300S sold @ 22k mi, Black '93 K1100RS traded @ 78k mi, Red '85 K100RS sold @ 44k mi, '06 Kaw 650R chrome yellow track bike sold http://www.seagullbb.com/
    Ohio
    Most of the bodywork is already off to do a brake bleed. Guess I might as well pull the tank. I have the Clymers and it does lay it all out. Of course the tank is clear full for winter storage. I have ordered steel disconnects from Beemer Boneyard since the tank will be off anyway.
    Jeff
    93 K1100LT
    Astatula, FL
    Also the rubber O-ring that seals the filter and pump plate tends to swell when you undo the assembly (gotta love ethanol!). You can let it sit a while and it will shrink back down, hit it with light heat from a hair dryer to speed up the process, or replace it and hang the old one up to dry out for the next service. In the summer, direct sunlight will dry it pretty quickly.
    Bob Weis
    Bikeless! 2004-bmw-k12rs-hannigan-Sold!
    Ohio
    Quote Originally Posted by Bobmws View Post
    Good to know. Thanks for the tip. Not a big fan of the ethanol either.
    Jeff
    93 K1100LT
