H
hmdalton
Hi everybody,
I'm new to the forum as far as posting or starting threads, but I've been doing a lot of reading about two things in particular, but have found nothing that really gets at my problem. So, here goes...
I have been trying for many days now to get all the air out of my front brakes. Have had some success with the "pounding the calipers with a rubber mallet and then 'flicking the lever to release bubbles" technique ( that used to work track-side when had brake fade from too much hard cornering on flat tracks. I've done the zip tie the lever over night thing as well, but I still can't get the lever to feel solid like it ought to be.
Does anyone have any counsel either encouraging or cautionary about reverse-bleeding the system? I've heard that can be anathema to servo-ABS modulators, but is it safe with ABS1? I've done that on my Beemer cars with excellent effect, but never with any having ABS.
Thanks in advance for any wisdom you can share.
Mark
Mark
