Make sure your seal is good between the driveshaft and the final drive. I had gear oil venting and ot wound up being the nut securing the pinion gear on the fd came loose and the driveshaft oil made its way into the fd and relieved. The final drive oil level always looked fine but if I.drained the driveshaft oil it was always low. It's easy to take the final drive off and check
